Potentially looking at acquiring a Helix of some description. Mainly for playing at home and for recording.
I like the rack form factor but appreciate the versatility and practicality of the floor unit. I like the price of neither.
I know there's like a huge thread on the Helix a couple of posts down, but I don't have time to digest 400 odd pages, so hoping someone can provide some simple wisdom and experience in short form.
So, riddle me this - is there any reason to choose either the rack version or floor version over the LT?
From what I can gather, the LT has most of the same features but a little less of the connectivity of the rack and floor? Is that about right? I think the mic pre is also dropped.
Ta very big.
Turns out there is an H in Haych! ~ Sporky
Bit of trading feedback here.
If you need more loops and the mic pre then get the Floor or the rack. If not, then the LT will be fine.
I got the rack as it’s the hub of my recording set up, and if I giggled again it keeps the brains off the floor away from the beer.
Will consider my options over then next couple of months.
I do have the foot controller and I do use it when recording or playing along to youtube etc but I can put it away when I'm recording most of the time. It can be useful for using a pedal to turn on and off noise gates as needed in a take, if I want a really aggressive gate for some staccato stuff.
I am very much a luddite when it comes to recording. I usually record with effects rather than add them later. I like a more live feel.
When you record then the USB7 output is a clean through. So always record with that as well as whatever sound you create and you'll always have something to reamp with other plugins or even back through the Helix.
Mine does all my PC audio - even when watching Netfix.
One thing that the foot controller can do (or the others with f/s) is that there is actually a preset that has midi control for controlling youtube - PLAY / PAUSE etc. That's very handy for playing along!
Its the same sounds as the hardware units, but in a software plugin and quite a bit cheaper than a rack!
Also, if you do buy a hardware unit, you get a massive discount on native.
I don’t. My perfect starting point of edge of breakup. Pick lightly, clean, dig in, bit of hair.
Yesterday I had a very old Marshall 9004 solid state rack pre amp in the workshop. Hadn't been used for 20 years and all the knobs were seized. I gave them some contact cleaner and fired it up and straight away it sounded pretty good. This thing has 7 opamps and 4 transistors ...that's it but it sounds great.
If I get time I want to do a video playing through all 3 to see if it's just me who prefers almost anything over the Line 6 tones.
On the flip side of this I've had a very love/hate relationship with the Helix amp modelling on Stomp/LT/Floor. Loads of people love it though!!!!
But again, as a control centre for a bigger rig the Helix Floor with 4 loops, scribble strips, etc is pretty unbeatable. Still got a broken Helix Floor (screen doesn't work) that sits under my DAW desk and is used mainly as a foot controller for punching in and out.
I recently had a Valeton GP200 for a few weeks. It has it's pros and cons and I returned it because it didn't meet my gigging needs....in brief, you can't see what effects are being activated by the control footswitches.
But you know what, it sounded great and was just more fun to use. It had no mic choices, you just select an amp and cab which was so much easier. It had some real knobs for tweaking amp models and overall there were far less parameters to worry about. Not as sophisticated as Pod Go but just more enjoyable to use with 11 fast access buttons to amps, cabs, fx and NR.
I wasn't sure about the footcontroller as I have a very good MIDI controller and Helix is pretty pi$$ poor in comparison for MIDI, but I got won over by the scribble strips which is the one thing my old controller lacks.
It sounds really good to my ears, although if I'm honest I barely use more than 10% of the models it has and once I find a virtual rig I like tend to just play. I only ever really spend a good amount of time with option paralysis when a firmware update comes out and I go through them again. Even when I choose a given FX sound I rarely go much past a small tweak or two.
I'd love a floor version as well for use outside my office / playroom, but can't justify it.
Thing is, it's not one of those bits of gear you can easily try out in a music shop - even if you purchased one online and exercised the 14 day cooling off period allowed in consumer law (which would still be a crappy thing to do), unless you had a good few days off work and without distraction, you'd still be hard pushed to explore its full potential in ever scenario in which you'd want to use it.
So it remains an expensive and risky purchase. I've watched lots of YouTube vids and it seems impressive from what I've seen and heard, but I don't know how long those players have spent with the unit and how long they've spent tweaking their sounds. But, it does seem very capable - I just don't have a very good track record with complicated pieces of gear that have lots of menu options. I tend to get option fatigue very quickly and my tolerance for scrolling through menus is low.
Thank you to everyone who has chipped in, I'll give it some thought and probably make an impulsive decision as I normally do. There might be a cheap Helix for sale in the classifieds soon, lol.
I also use it to get my presets right before I export to my Stomp, then just adjust slightly when I play with the band. (I'm just using the effects into the front of my amps.) My co guitarist is disparaging about digital kit but then complements my sounds when he can't tell if it's the Helix or not. I've gone "Stomp only" now so there's no denying it
I would say:
1. For years I didn't need the extra connections of the full Helix. Now I'm doing guitar lessons online, I wish I could plug a mic in to the Helix. You can do that on the full Helix. A minor thing though.
2. If you want to minimise complexity and menus, it might be worth looking at either the UA pedals or the Boss IR2. The Boss also functions with headphones and as an audio interface I believe.
