Appreciate.
I’ve seen some atrocious Gibson finishes even in 2023 with the latest management.
But some of the Tributes are a bit of a bargain if they are pre-crazy price rise.
I'm facing a similar issue with my Epiphone Les Paul Classic. Ever since I got the guitar I've been wanting to get nickel silver covered humbuckers for it – purely aesthetics, which is why it's been in the back of my head for 2+ years. Problem is, it's got all these computer-style connectors and PCB mounted push-pull CTS pots to handle coil splits and phase reversing. I've spoken to a couple of pickup builders and they've recommended gutting it and putting a 'decent' loom in along with new pickups. I don't use the coil split or phase reversing as much as other people. In fact, I don't think I've ever recorded any 'coil split sound'.
This is what it looks like inside:
This guitar is also quite precious (present from mum and wife when I got back to playing guitar after 20+ years), so I would try to avoid woodwork and such.
Thoughts?
Many thanks,
Jon
My trading feedback: https://www.thefretboard.co.uk/discussion/210335/yorkie
Or you could add connector blocks to a set of regular four conductor pickups and hook them into the existing wiring
If you can't find the blocks a third option could be to snip the existing bocks off with some excess and solder the excess onto the new hookup wire (with heat shrink over the connection)
If you do want to rip out the existing harness, I recently did a friend's Epiphone LP with these pots and I really like them: https://www.axesrus.co.uk/Medium-Shaft-Alpha-Pots-p/medalpha.htm
I spot a CTS pot in your photo so the holes are probably already wide enough to fit US size shafts. Epiphone LPs take medium shaft pots
https://imgur.com/a/4edBwa4
https://www.thefretboard.co.uk/discussion/202071/nco
