In case it's of interest to anyone else with the same amp.
I've noticed a harsh buzz, over the top of the usual mains hum, which creeps in a few moments after the amp has been switched on. It seems to get louder the longer the amp is on, and still happens when the amp gain and volume is at zero with nothing plugged in. This amp is absolutely brilliant with drive pedals, both for home practice and rehearsals/small gigs, but the buzz is getting really annoying.
The buzz persists using the amp in different locations.
I wouldn't swear to it, but I don't think it used to do this - I got the amp around 2007 and don't remember noticing the buzz.
Last new set of valves was around 2008. The amp's only been cranked a few times since, but has seen almost daily use most of the time.
Step one (thanks to jpfamps for his guidance) was to push the ribbon cables from the output valves away from the blue lead from the OT. Unfortunately the problem still persists.
Next step - I've ordered a fresh set of valves (JJs with matched pair of EL84s) - at the same time as I fit them, I'll change the voltage to 240V, which as I understand it is a matter of swapping a couple of connections. I unplugged the amp yesterday so hopefully caps will be fully drained!
Fingers crossed - will check in with results.
Feedback
