Tuners. TC Electronic or Korg?
markjmarkj Frets: 914
I know a tuner is a tuner but which is your fave tuner on your board?
  • springheadspringhead Frets: 1601
    TC. I’ve got a two boards with Polytune minis on. And a clip on one. I like the poly trick - strum all six strings and it shows you a rough view of in tune, sharp or flat. Good for a quick check between songs mid gig.
  • susbemolsusbemol Frets: 403
    Korg for me.
    There are a few models to choose from, mostly with a decent sized and bright display that works well pretty much anywhere and last forever.
  • Boss TU-3 - I never found the poly modes on the TC to be particularly useful, and prefer the footswitch/enclosure of the Boss.
  • ElectricXIIElectricXII Frets: 1137
    TC Polytune on my gigging board. I've got a Boss TU-3 as a backup, but I find the Polytune easier to use.
  • Fingers657Fingers657 Frets: 657
    My favourite is the Peterson STROBOSTOMP HD.
    The Boss is great built like a tank.
    Not the Waza version the light in the dark is a pain to see properly.
    The Behringer clone of the Boss is excellent value for money and works just aswell.
  • thomasw88thomasw88 Frets: 2332
    Boss tu3..  it'll last for ever and just works
  • NelsonPNelsonP Frets: 3402
    Polytune mini. Does everything, takes up little space. Tried a korg mini but not in the same league so returned it.
  • PennPenn Frets: 627
    I have a boss. Works well and built like a tank.
  • HeadphonesHeadphones Frets: 992
    I have an A440 tuning fork.
    Doesn't even need batteries, is easy to amplify and works on acoustics.
    The joy of learning guitar in the early '80s.
    Until you're in a room with lots of other musicians warming/tuning up and you can't hear it.
    Better learn to tell the pitch from the vibration then!
    From the '80s, so they tremble before my twin Marshal stack!
  • I own a TU-3 these days. Absolutely fine,  but it's not being used any more coz the tuner on the H90 is also fine and that makes it one less thing to carry/cable, etc. I have a headstock tuner as a spare, just in case...
     I used a Korg Pitchblack for 15+ years and that was equally fine.
  • NeilybobNeilybob Frets: 797
    Korg for me. Brilliant and easy to use.
  • markjmarkj Frets: 914
    I think I will stick with the Korg.
  • TTBZTTBZ Frets: 2911
    edited February 18
    I use a Korg Pitchblack and have done for years. Before that I had their DT10 but the switch died after a few years of heavy gigging.
  • RaymondLinRaymondLin Frets: 11893
    I've got 2 TC Polytune mini, easy to use, small, works.
  • RockerRocker Frets: 4989
    StroboStomp every time. Perfect for BFTS and sweetened tuning.
    Nil Satis Nisi Optimum
  • I used the TU-3 for a long time. As with all Boss pedals, it's a well built thing and perfectly functional. Then I got a Peterson StroboStomp HD. The accuracy, large screen, sweetened tunings etc make it the best tuner I've used to date. I'm a convert to Peterson and use the StroboClip on my acoustics now too.
  • TimmyOTimmyO Frets: 7528
    I have the D’Addario one
    I like the idea of the Peterson one but I’m too tight to spend that on a tuner
    Red ones are better.
  • fretmeisterfretmeister Frets: 24518
    TC.
    On bass I find the TU-3 quite jittery. It's annoying.
