evh 5150 standard
dazzer22dazzer22 Frets: 44
Does anyone know how i should adjust the pick up height , I just want to add more height ,  i am more use to being able to adjust them with screws on my other guitars .
  • strtdvstrtdv Frets: 2590
    Bending the legs seems to be one option, or add a shim underneath the pickup plate
  • paulnb57paulnb57 Frets: 3222
    Foam under the pickup ( to act as a spring and possibly longer screws) or a spacer under the pickup foot to shim it up to the desired height
  • FunkfingersFunkfingers Frets: 15276
    Compressible foam between the humbucker baseplate and the cavity floor.
    If you cannot find wide foam pieces, prevent the pickups leaning over by using two narrow, "Jazz Bass" sized strips, positioned roughly in line with the edges of the baseplate.
