So I bought a new matched set of 6L6's for a cathode biased amp, the old JJs work but one of them is really microphonic. Other than that they're great.
Stuck in the new set, amp started to smell hotter than previous or so it seemed? Not burning as such, just hotter. Then there was an increase in noise floor so I had a look. One of the valves was redplating so it seemed.
Tried them again after switching off, this time there was a few crackles and I got the pics below, kind of a time lapse from standby to on, to a minute or so after. I removed them and put the JJs back and aside from the rattle, they're working fine with no redplating.
I spoke with the vendor and they're asking me to try the valves again and switch them around to see if the problem stays with the valve. They even suggested it's just the valve settling and burning off contaminants. They have offered a replacement once I've tried that stuff so they are being decent.
What do the techs here think? Can I damage the amp running redplating valves to see if they settle? The fact the old JJs are fine is throwing me off!?
Thanks all,
Al
The yard is nothing but a fence, the sun just hurts my eyes...
(Assuming it stays with that valve when you swap them round.)
Don’t run it any longer than just to check that.
The JJs run without issue.
Currently chatting with the vendor as they're seemingly asking me to pay return postage.
Hotrox or Watford?
If so, expect the faulty valve to magically test fine when returned…
Luckily neither of those vendors, Watford I wouldn't patronise if he was the last valve dealer on earth, and Hotrox I haven't used for a while
Dealer has agreed to return shipping and replacement luckily, so I might even avoid switching them around now, even though I'm sure it's the valve.
I know it's unlikely, but still.
