The nut slots only needed a little widening so I didn't need a new nut when I went back.
I‘ve done it on a couple of Teles using a double-ball-end bass string with the small ball end, which fits in the ferrule. I used a 65-gauge, which was also the largest that would fit in the tuner post.
You could probably get away with 11s because the B in a set of 9s is an 11, but in fact it’s a bit too light and should really be a 12 - I think something like 11, 15, 22W, 34W, 40W (roughly the bottom 5 strings in a set of 8s) and about a 52 or 54 low B would still work.
You do need to widen the nut grooves, but if done correctly with smoothly rounded bottoms (I know…
There is a tightness and a tautness to it which an E standard guitar doesn’t have, without it being too bass-like. I imagine using the same strings on a 25.5” scale would give a lot looser feel.
For lower tunings, longer scales feel and sound more like a guitar than just sticking very thick strings on a normal scale length
I recommend D-D on 27 inch scales, B-B on 30 inch
I tried a 7 string, then got a very nice 8 string Schecter
I found it tricky, but certainly it does give you more options
so for once bought a new guitar, the 6 strong 30 inch version of the Schecter. I still love it
I want guitar-like top 3 strings, with deep bass on the bottom
I did buy an 8 string Harley Benton bass, which I planned to restring as an XRG
(Extended range guitar) - idea was to use normal guitar gauges on the top 3 or 4. However, it was hard to get ones with the right size ball ends, and I lost interest in the project, when I saw them selling used for more than I paid new
Definitely personal taste. And perhaps physical size lmitations! I would struggle on an 8 string and end up hurting myself
I suspect that applies to most! I have a propensity for exploring deep rabbit holes...
