I think they’re a one trick pony. Great trick though!
Then too high above that you really need to work hard to stop it squishing out, sounded fine with a treble booster to cut the bass frequencies.
The Chris Stapleton might be a better option? For me it sounds better across the entire volume range, and not so in your face loud.
I would just add, that if the Hombre hits “that sound” you are after - then it’s a home run.
I had to swap out the speaker several times till I found one I liked. The amp has a lot of mids and the top end is warm, so having a slightly brighter speaker can help.
It is the last amp I would choose for clean sounds, but if I was going for Billy Gibbons dirty blues its is pure joy
The amp has loads of bass in the circuit which can lead to farty sounds/blocking distortion. That can be fixed with a boost pedal or EQ pedal out front.
A close relative to this amp is the Marshall 1974x which is a little tighter and has a slightly different drive sound due to the EL84s and the lack of blocking distortion.
https://www.youtube.com/watch?v=Cs3U3YOVLn0
