Depending on which version of the G series it is, you may need an even more specific type that the pickup fits directly onto, rather than being a flat strip under the saddle. If so, you need one of these - https://www.ebay.co.uk/itm/172351092251 - take the existing saddle out and have a look.
Not cheap, but there's a lot of work in making those.
If you're making one from a typical plain blank you would be able to get the two halves out of one piece though.
