I have medium-size hands but started on nylon guitars (50mm nut), then played mostly 12-strings for the next several decades (48mm or 50mm nuts). Anything smaller that that still feels cramped to me, though I have gradually become more-or-less used to the common 44mm and 44.5mm instruments.
The thing is, guitar makers go to endless trouble making (largely cosmetic) model variations like sunbursts, dyes, fancy inlays, different pickguards with signatures on them, different back and sides timbers - all things which have small to zero effect on the practicalities of the instrument.
But try to buy a guitar with a real and practical difference - easy enough to make and near-zero extra manufacturing cost - such as a wider or narrower neck, and nope. You are lucky if you get two choices. In most cases you get only one. Try buying a Maton or a Cole Clark with a 43mm nut. Nope. Or a 46mm or 44.5mm nut. Still nope. 44mm is all you get. Like it or lump it. Try buying a Guild, a Taylor, a Takamine, or a Martin with anything other than 43mm or 44.5mm. Nope. Worse, you get shafted with inflexibilities. I would rather like a Takamine New Yorker (their name for their various small body guitars) - but it is (almost) impossible to find one with a standard 44mm or 44.5mm nut. They all use 43mm, so I'm screwed. I can't play a nut that tight. Bigger Tak models mostly use 44.5mm, so with them, @crunchman, you are screwed.
