WANTED - inexpensive hard case for classical guitar
impmannimpmann Frets: 12678
As above - looking for a "good value" case for my classical. Tatty is no problem. Its for storage in the house, mainly.
What have you got?
  • BillDLBillDL Frets: 7389
    edited March 19
    If you don't get a proper hard case offered here and end up having to buy one, you might want to consider a hard foam lightweight case.  I have several of my acoustic guitars in them.  They aren't horizontally "stackable" like a hard shell case would be, but are pretty rigid and sit nicely between hard case and padded gig bag.  I tend to slide a piece of thin foam (white extruded polyethylene) into the front zip pocket for added protection because I don't use that pocket and it's not much good for anything but a notepad or a packet of strings anyway.
    The Gear4Music and Harley Benton ones are most likely made in the same factory, and they are cheaper than the Kinsman or Gator equivalents.
