Evening all. Just getting both strats sorted for the year and wanted to see whether the set ups needed attention. Full disclosure, I don’t know what I like or need measurements wise other than wanting to avoid buzz and to play nicely. Am I am still learning about setting stuff up. So I thought I might ask for some advice from a few folks who are experts. If I was closer, I would simply drop them off at
@FelineGuitars ! Both have plenty of fret material left, and not a lot of wear. Strat 1- custom shop strat- 9.5” radius neck, 10-46 strings.
Using a capo on 1 and pressing down at the 17th fret, I measured relief using feeler gauges on the 7th fret. Every string was .010 apart from the B string at .008. So it’s pretty much bang on fenders recommendation for a 9.5” neck which is .010.
Removing the capo, I get the action at 1.75mm on the low E and A , and 1.5mm on the rest. I don’t get any buzz on this normally and while it’s not super low, I am guessing this might be considered a medium set up. Fenders recommended action is 1.6mm on all strings. So while I am not gentle when I play, I am guessing this is probably about the right set up for me. I am thinking then that all it needs is a clean, polish the frets using a dremel and autosol, some oil on the fretboard, dab of nutsauce in the slot, restring, check the intonation and that will be ok.
Vintage strat- 7.25” neck
I don’t know what strings I got with this but last year I did re string with 10s. I didn’t adjust the truss rod but I did screw in the claw a little to compensate for the trem plate rising a little with the new strings…. So I guessed they were 9s. There are skinnier frets too. Measuring the relief it’s a little flatter. I got .003 on the low E and A, .004 on the D, and then .006 on the rest. Fenders recommended relief is .012 so it’s quite a lot flatter.
fenders recommended action is 2mm on the bottom E to 1.6mm on the top. I get 2.25mm on the bottom E, 1.75mm on A and D, then 1.5mm on the rest. But I do get a buzz sometimes only on the bottom E. so I am tempted to put a little more relief into the neck just to alleviate the buzz on the bottom E. Then a clean and polish as per the other guitar.
So while I don’t dislike the setup on either, I am not overly experienced in the art of the possible so while they feel fine to me now, is there anything I am missing? Thoughts and opinions welcome
An official Foo liked guitarist since 2024
It sounds like both guitars are set up perfectly well.
To avoid buzz on the low E I tend to have the E and A set a hair below 2mm.
Fret buzz at the low frets tends to be caused by the truss rod being a bit tight (assuming no high spots on the frets or fretboard), while buzz at the high frets tends to be caused by the saddles being too low.
In an ideal situation you want a pretty even action the whole way down the neck (ie the action at the 12th fret within about 0.2mm of the action at the last fret (21 or 22 depending on which Fender).
On most guitars you can get this with a combination of truss rod and saddle adjustment, but occasionally you'll need a shim.
I've never ever set-up a guitar with any form of measurement device, or with a view to achieving a specific measurement - I can understand it as a guide line of what you think you might need/want - But I personally set-up any guitar based on feel - Not all guitars are equal, even 2 similar Strats, so hard to get both to play in exactly the same way - Similar yes, but DNA replica of each other ? then probably not
Hard to advise you as a) don't have the guitars in front of me to see if we can improve the set-up to suit you and b) un-sure of your skill levels in order to suggest various options - In some ways your best bet is to visit a good tech - Let them look at the guitars, then watch you play to get an idea of what you might need - Then they can hopefully make suggestions to suit - A good tech should be making suggestions and adjustments to suit you and your needs and certainly not making adjustments to suit them
A lowest action possible is not always a set-up that suits everyone - Many times I've had to take my 'shop' set-up and raise the action a touch to suit - It is unlikely you'll get the original old Strat to match the 'fluidity' of the CS , based on a 7.25" radius and smaller frets
Personally I have almost no relief on my set-up but a) I like a 'piss easy' action and b) I pick very gently, as such smaller string vibration, hence less chance of any string rattle - But such a set-up won't suit all
A couple of weeks ago I posted a comment on FB about setting up a CS Strat that had just come into stock - At first I was not happy about the end result, taking into account it was an expensive CS model - I wasn't not happy about a 'that will do approach' - So a day or two later I gave it another tweak - Probably only a gnats whisker here and there - Bottom line was the end result that I was hoping/expecting - As I said earlier, hard to describe the exact nature of what I'm doing, as to be honest you are kind of making it up as you go along, certainly experimenting with adjustments available to you on that actual guitar - So you feel your way in to it
Hope that makes sense but let me know if I can help further
key is to do a small amount- tune back up - check- then repeat if necessary- With truss rod adjustment I’d leave it for a day or so to settle down and bed in, then repeat if necessary
And remember that a low-ish action is not for all players - I have a Collings i35DLCX in stock - Customer came to try and buy it this week - Instantly felt to low and a touch 'rattly' for him - Checked his Gibson 335 (that he brought up with him) to see how that was set-up and the Collings was significantly lower - That doesn't mean the Gibson was set up wrong, as it wasn't, it is just that the 335 set up was his 'bench mark' - But generally far easier to raise an action a touch, as required as you are taking the strings away from any potential 'rattle' areas
Many guitars have a re-sale value. Some you'll never want to sell.
Stockist of: Earvana & Graphtech nuts, Faber Tonepros & Gotoh hardware, Fatcat bridges. Highwood Saddles.
Expert guitar repairs and upgrades - fretwork our speciality! www.felineguitars.com. Facebook too!
I have no idea if that would be the consensus here - but I did raise mine sightly to 1.75 at the high E and 2mm at the low - and find Im much preferring that extra height.
Mine (low E, 12th fret) is about 3mm. That's as low as I can get without loosing sustain and tone (caused by string hitting frets) when I dig in.
I do like to whack the strings from time to time.
I did lower it slightly a while back, seems alright now.
