Both are great but I'd like a jazzmaster one day.
In terms of technique it's worth noting every different guitar will put the Bigsby handle in a slightly different place, compared to a Strat where any difference can only ever come from the shape of the arm, but you get used to it easily.
I have an ES-330 and ES-355 and I have no problem keeping hold of the arm while playing a lot of stuff. Tuning is really solid on both. A really well cut nut & saddle combined with domed thumbwheels does the trick
You can play with it hooked by your little finger but you have to get used to hitting the stop on the arm bracket...pissed me off so much with my first Bigsby that I replaced it with the Callaham 360 upgrade. However, second time around, I just got used to it as one of the quirks.
@GoFish I agree on the JM-style system...it's an awesome thing
There are differences in the way they both change the relative pitch of notes within chords, which gives them distinctly different sounds - the Strat has no string length behind the bridge to take up some of the slack, so the thicker strings detune faster relative to the thin ones. This makes the Strat more 'dive bomb' sounding than the Bigsby - the extreme version of that is a Floyd Rose. A Bigsby keeps the strings slightly more in relative tune, and is also less prone to bent strings pulling the others flat, so if you play a chord and bend one note within it the two types sound different again - the Bigsby is more subtle and shimmery, the Strat is more detuned-sounding.
All the different types of vibrato are also affected by the length of the strings at the headstock - eg the Floyd (none) to the Strat (thin strings with much more slack than thick ones) and Bigsby (usually on 3-a-side guitars, to the Es detune more than the middle strings) - that's also why a reversed headstock sounds different on a Strat, like Hendrix.
