Addictive drums or EZ drummer
  • BodBod Frets: 1316
    I do everything in the VSTi initially, then render it into the DAW as separate multi-out audio tracks usually.  I used to drag and drop the MIDI, but the grid editor in the plugin is better designed for making edits IMO.
  • guitarajguitaraj Frets: 47
    EZ Drummer users: do you make the arrangement in EZ and then paste the whole thing into the DAW, or do you drop in separate sections and arrange it in the DAW?
    You can do either I think. I prefer to grab the midi parts and then edit them on the Logic midi track as required but YMMV
  • euaneuan Frets: 1503
    Are there any good EZ3 tutorials out there?
  • octatonicoctatonic Frets: 33806
    I do everything in Logic's Piano Roll, because I am faster with that than I am in the plugin.
  • Vintage65Vintage65 Frets: 335
    Both!
  • SnapSnap Frets: 6265
    I get on fine with AD2, I like the kits, the interface, the flexibility and the fills are very good. I think it's a lot to do with what people are used to. I haven't used EZ. A pal of mine has both and thinks the kits and fills are better in AD. Maybe try a demo of each, make your mind up from that?
  • Axe_meisterAxe_meister Frets: 4648
    Have invested in EZ Drummer 3
  • duotoneduotone Frets: 988
    You won’t regret it, EZD3 looks & sounds great. It’s brilliant for practicing & using as a songwriting tool. Enjoy!
    How are you getting on with it @Axe_meister ?
    Not had enough time on it yet (mother in law at home for 5 weeks). So far just sticking on some midi loops for practice
