Valve issue?
bencowling81bencowling81 Frets: 420
My Maz 18 when turned up is intermittently losing volume (not completely but I'd say at least half), then comes back in, almost like a very very slow tremolo effect. Is this common and is it likely a valve issue?
Any help much appreciated.
  • ecc83ecc83 Frets: 1637
    When it dies next time try to check if the heaters have dimmed  you might have a bad joint some where in the filament circuit.
    Dave.
  • ICBMICBM Frets: 72484
    This. Slow fade out and back in is a filament issue, either one valve or the whole supply. The first thing to do is check if it affects all the valves or just one.
    If it’s just one, it could be as simple as a dirty contact between the valve and the socket.
  • bencowling81bencowling81 Frets: 420
    Thank you @ecc83 and @ICBM - I’ll try to see what’s happening around the back next time it does it.
