Q2) Does Reaper already support plug-in virtual instruments?
Q3) Do you know any music theory? (e.g. Harmony and counterpoint.)
If the answer to all three questions is yes, you can probably enter the note pitches and durations in to Reaper already with a combination of your computer keyboard and mouse.
Unfortunately, any synthesizer or sample replay virtual instrument is unlikely to sound quite like a bunch of humans, playing violins, violas, cellos or contrabasses in a sympathetic room.
Finally, is Reaper already Orthodox, Conservative or Reformed?
You can program it in with a keyboard or you can pencil it in on the midi roll like you would with any other midi instrument in reaper or and DAW.
Grab that (free) and a simple midi controller (which will connect via USB into your PC/laptop, not midi!) and you're all set. I've got an Akai MPK Mini for simple stuff, and an Oxygen49 for when I want to get more fancy. The MPK Mini also comes with some other downloadable plugins, so you can use more sounds than just the Spitfire Audio plugins.
If you want to learn some keyboard basics, Pianoforall is a great place to start, and is often available on Udemy for ~£15 (steal).
The other instruments all sound great though. I wonder if there's something I couldn't find to set the swell/attack to be much less
soundcloud.com/thecolourbox-1
I haven't done them for a while but I recall that with bowed stringed instruments the player will naturally attack the note a little ahead of the beat due to the style of sound without a transient so you will find that you need to place all/nearly all of your notes a little off the grid, ahead, to get the correct feeling and have everything gel. It takes some practice but you can definitely notice the difference and will get an aha moment as you move things around and it all starts to sound natural..
I really only came here to be a dick ^ but in answer to the actual question, if it's for string pads etc on rock music I find synth strings actually sound pretty acceptable. Of course you're not going to get all the subtle nuances of real strings very easily with a keyboard but in a rock mix I'm not sure it really matters. But having said that, my daughter's a pretty good string player so when we've wanted strings on the odd recording we usually ask her to do it... so I may not be practicing what I preach
Try to avoid just chucking down block chords.
If you want to learn then The Technique of Orchestration by Kent Kennan is a good place to start.
I'll have another go and see if I can find the controls and if dragging the parts back a little into the pocket works, otherwise Native Strings sound fine so I'll just keep using them. They just aren't free like the Spitfire one for the OP's purposes
The occasional big chordal shift can be quite effective as contrast.
I'll give that book a look - ta.
