Selling a pre-made Jimmy Page wiring harnesses from SixStringSupplies.
Fantastic condition and fully working - only works with Gibson Les Paul guitars. Please also ensure your cavity measurements match the spec as per the diagram.
Please also note that you must have 4 conductor wire pickups to use this.
The Jimmy Page wiring harness gives you near unlimited tonal control and options, offering 21 different possible combinations to choose from.
The push pull pots allow you to coil split each humbucker, play both pickups in series together or out of phase with each other. This prewired kit is wired in the popular "50s" Les Paul® style, reducing the loss of treble as the volume is rolled back.
This kit is completely solderless - using high quality terminal blocks and a printed circuit board, installation could not be easier. PERFECT for quick and hassle free pickup swaps.
Jimmy Page harness controls:
All controls in down position - normal Les Paul® (50's style wiring)
- Neck volume up - neck humbucker coil split
- Bridge volume up - bridge humbucker coil split
- Neck tone up - neck and bridge in series
- Bridge tone up - neck and bridge out of phase
