FX less pronounced when using acoustic IR? (HX Effects)
Loaded up some IRs to try with my HX FX and noticed that my boosts and chorus now less pronounced ie I get very little level increase and barely hear the chorus effect. It doesn't seem to matter where in the chain I place the IR. This is my first time dabbling with IRs so I'm assuming I've done something wrong! Any ideas?
I used a few from this site: Acoustic IR (free.fr)
Cheers
Ronnie
  • StratavariousStratavarious Frets: 3705
    Is there a IR mix level? And can you change where in the fx chain the IR acts? E.g earlier?
    Not familiar with that device
  • TTonyTTony Frets: 27696
    Certainly with the 3sigma IRs that I’ve got, the default level can be set quite low, so everything sounds quiet and benefits from a bit of fiddling to get a better balance.
  • LongtallronnieLongtallronnie Frets: 1201
    IR is first in chain and I think the mix is set to 100%
    I think I’ve managed to tweak everything so it works with the IR but I’m having other issues which might be related to a newly fitted pickup. And a dodgy speaker lead. And some loose internal wiring. Basically there’s lots of shit to sort out!
