Further to my thread about small valve amps for pennies, i'm hovering over a Princetown kit from modulus.
Most likely it will end up as a combo of some kind but as I have a spare sub zero 10" cabinet i thought I'd wedge it in there. My questions are , rather than put it at the back of the up and facing upwards, could I fit it above the speaker at the front at an angle, i'll happily remake the baffle and move the speaker down and across. Has anyone got the princtown kit and have dimensions so I can see if the valves will clear?
Im not averse to it being at the back but I'd much rather have the knobs at the front (I know there's only two of em but still)
Firstly, I've built a Modulus (not the Princetown, tho) and they're great kits with top components and support from Michael. Enjoy!
Secondly, If it were me, I'd go head and cab if you want to use the sub zero because:
a, It would be cramped and difficult to refinish the cab, grill and baffle after the modifications, and,
b, a lot of people enjoy a Princeton through a 12" speaker and you'd leave your options open.
Sorry for not answering your questions properly, just some random thoughts!
It's a great kit though, my first build and it all went well. I've modded it slightly since with a power reduction circuit (attenuator) and a switch to remove the negative feedback circuit. The layout supplied by Modulus is excellent to follow.
If it's of any use here's a link to some photos of my build.
https://photos.app.goo.gl/af9Yhg5tsF765Rzg9
Cheers,
Graham
I've read the safety pages and will make sure as I go that everything is as it should be, I've got amps so there is no rush to get it done in any particular time frame.
Honestly making the cab/combo box worries me more as woodworking is not my forte, but a bit of practice and i'll get that sorted as well.
ta for the help and advice everybody
I found, tackle it little by little, I done half an hour here, half an hour there.,
I printed 4 copies of the layout out. I marked the wires off on the lay out as I attached them, I then double checked. Same with the turret board. then I had a last check, again ticking off the connections, double checking comp values ect.
Here is a link to a few photos I done of mine.
https://photos.app.goo.gl/qaq42EzGwz1xttYx5
eek, i've gone and ordered it, now to start collecting my wits, reading as much as I can about it and clearing a space in the workshop so I can build it. Ordered without cabinet (i'll utilise something I have here or make a headshell for it) or valves (i'm lucky enough to have a 12at7 already here and a friend is sending me a 4 12ax7 (so i'll have a spare) and a GZ34, so i'll have to get some 6v6's but I'll see how the build goes. I'm not going to rush it but I will take plenty of pics as I go and start a thread if anyone is interested.
Much excitement/trepidation/outright fear at the spev11 house
