If you want the amp to give your drive at low volume, maybe something like an MXR Microamp into the front would do what you want/need/like.
IE no gain, just boost the signal into the front, for some extra dirt.
I don't think the sov is the right one for this I have the SOV2 and the original Matt Schofield one and they are over drive pedals, they push the amp sure but they add over drive too. If you want to push your amp this isn't the right pedal and it's also an expensive solution.
Keeley Katana works great for this and I use it with a very similar amp.
http://www.guitarguitar.co.uk/pedals_s_detail.asp?stock=06020317220629
JHS prestige will push your amp perfectly
http://www.guitarguitar.co.uk/pedals_s_detail.asp?stock=14030314445916
Guitar guitar have this pedal at a bargain sale price and works well too
http://www.guitarguitar.co.uk/pedals_s_detail.asp?stock=12061810210439
they will all push your apm MUCH better than a sov and they are a lot cheaper.
If you want to throw money at it
http://www.bobburtcabinets.com/#!__store
The bob burt clean boost is by far the best clean boost I've ever used, lower the volume on your amp and use the boost to push it - works great.
the SOV is a super pedal, but it is overdrive and will add it's voice as it pushes your amp, the solutions above won't do it and you'll get a good return on your amps natural sound.
