FS/FT Guild D55e antique sunburst REDUCED
SOLID SPRUCE TOP, SOLID ROSEWOOD BACK and SIDES
https://imgur.com/a/AZvceGOStunning guitar, bought during Covid. Unfortunately I am only a home player and to be honest I find it a little too big for late night practicing/noodling on the couch.
So I am looking to trade for a smaller acoustic, happy to consider most things.
If you happen to have a custom tele or Gold top Les Paul with p90s that would be of interest too
Sell for £2600, trade value a little higher. Condition wise, it's excellent still has protective cover on pick gaurd. Based in Durham, I am retired so can travel to meet (within reason).
Thank you for looking.
Mark.
SPECS
Body Shape | D - Dreadnought |
Body Top | Solid Sitka Spruce |
Top Bracing Pattern | Scalloped X |
Soundhole Diameter | 4" (102mm) |
Rosette | Abalone and ABS Ring |
Top Purfling Inlay | Black and White ABS |
Body Sides | Solid Indian Rosewood |
Body Back | Solid Indian Rosewood |
Body Binding | White ABS |
Neck Material | Mahogany with Walnut Center Strip |
Scale Length | 25 5/8" (651mm) |
Neck Shape | C Shape |
Nut Width | 1 11/16" (43mm) |
Neck Thickness 1st Fret | 21mm |
Neck Thickness 9th Fret | 22.5mm |
Truss Rod | Dual Action |
Truss Rod Wrench | 8mm Socket Wrench |
Fingerboard Material | Ebony |
Fingerboard Radius | 12" (305mm) |
Fingerboard Inlays | V-Blocks - Mother-Of-Pearl and Abalone |
Frets Total | 20 |
Fret Type | Jescar 43080 |
Color | Antique Burst (ATB) |
Finish | Gloss Nitrocellulose Lacquer |
Bridge Material | Ebony |
Bridge String Spacing | 2 1/8" (54mm) |
Bridge Pins | Bone |
Saddle Material | Compensated Bone |
Hardware Finish / Plating | Gold |
Nut Material | Bone |
Tuning Machines | Gotoh® SE700 Open-Gear |
Endpin | Endpin Jack |
Pickguard | Tortoiseshell |
Electronics | LR Baggs Anthem with Volume, Mix, and Phase Controls |
Strings | D'Addario EXP16 - Coated Phosphor Bronze Light (.012 - .053) |
Included Case | Guild Premium Humidified Archtop Wood Case |
Upper Bout Width | 11 5/8" (295mm) |
Lower Bout Width | 16" (406mm) |
Body Depth Upper Bout | 4" (101mm) |
Body Depth Lower Bout | 5" (127mm) |
Body Length | 20" (508mm) |
Overall Length | 41 3/4" (1061mm) |
Wish I could justify buying it myself. The low end growl I heard on an Acoustic Letter video was something I have to hear in person some time.
