FS/FT Guild D55e antique sunburst REDUCED
DeepBlueWitchDeepBlueWitch Frets: 51
edited June 12 in Acoustics £
SOLID SPRUCE TOP, SOLID ROSEWOOD BACK and SIDES
https://imgur.com/a/AZvceGO
Stunning guitar, bought during Covid. Unfortunately I am only a home player and to be honest I find it a little too big for late night practicing/noodling on the couch.
So I am looking to trade for a smaller acoustic, happy to consider most things.
If you happen to have a custom tele or Gold top Les Paul with p90s that would be of interest too
Sell for £2600, trade value a little higher. Condition wise, it's excellent still has protective cover on pick gaurd. Based in Durham, I am retired so can travel to meet (within reason).
Thank you for looking.
Mark.
SPECS
Body
Body ShapeD - Dreadnought
Body TopSolid Sitka Spruce
Top Bracing PatternScalloped X
Soundhole Diameter4" (102mm)
RosetteAbalone and ABS Ring
Top Purfling InlayBlack and White ABS
Body SidesSolid Indian Rosewood
Body BackSolid Indian Rosewood
Body BindingWhite ABS
Neck
Neck MaterialMahogany with Walnut Center Strip
Scale Length25 5/8" (651mm)
Neck ShapeC Shape
Nut Width1 11/16" (43mm)
Neck Thickness 1st Fret21mm
Neck Thickness 9th Fret22.5mm
Truss RodDual Action
Truss Rod Wrench8mm Socket Wrench
Fingerboard MaterialEbony
Fingerboard Radius12" (305mm)
Fingerboard InlaysV-Blocks - Mother-Of-Pearl and Abalone
Frets Total20
Fret TypeJescar 43080
Finish
ColorAntique Burst (ATB)
FinishGloss Nitrocellulose Lacquer
Hardware
Bridge MaterialEbony
Bridge String Spacing2 1/8" (54mm)
Bridge PinsBone
Saddle MaterialCompensated Bone
Hardware Finish / PlatingGold
Nut MaterialBone
Tuning MachinesGotoh® SE700 Open-Gear
EndpinEndpin Jack
PickguardTortoiseshell
Electronics
ElectronicsLR Baggs Anthem with Volume, Mix, and Phase Controls
Other
StringsD'Addario EXP16 - Coated Phosphor Bronze Light (.012 - .053)
Included CaseGuild Premium Humidified Archtop Wood Case
Upper Bout Width11 5/8" (295mm)
Lower Bout Width16" (406mm)
Body Depth Upper Bout4" (101mm)
Body Depth Lower Bout5" (127mm)
Body Length20" (508mm)
Overall Length41 3/4" (1061mm)
  • goldtopgoldtop Frets: 6301
    Link works. Here's one of the photos:
    Wish I could justify buying it myself. The low end growl I heard on an Acoustic Letter video was something I have to hear in person some time.
  • DeepBlueWitchDeepBlueWitch Frets: 51
    Thanks Goldtop, appreciate it
    Sunny day bump
    Surely someone would like to upsize their guitar
    Bumperty bump
