As for leather either the "hell for" type or made from one of your enemies hide, in Texas naturally.
Okay...well let's have a good discussion about this! First I'll mention that there's a paper kicking around at NIST that does a good job of examining screw holding power. You can look that up if you want to. End grain holding power is extremely erratic. I think you'd expect that because once you shear the fibers, you're begging for cracks to form, just as you expect wood to split when you whack it with a maul.
Anyhow, tensile failure, where the thing is just pulled clean out, are very rare. Sometimes it's so bad that you CAN pull it out, but the real failure mode takes time and is due to two things:
1) the button is loaded cyclically in shear...this compresses the fibers and loosens everything up over time. Ideally, a properly torqued screw isn't ever loaded in shear, but that just doesn't happen with strap buttons, especially when they loosen up
2) and they loosen up because the end grain fibers with the dinky little screws shear, compress, and start to split, and the more you tighten the screw, the worse it gets. Not only do the screws normally come out with lots of mangled wood stuck to the threads, I've seen them actually pull a neat plug out of the wood, sheared cleanly along the edge of the fibers.
Once either one of those things that to happen, any attempt to tighten the button just puts more stress on the wood and eventually makes it worse.
The path to longevity is to completely harden the area so that the screw can't wiggle around and move because as you know, if it can't move, it generally can't break. One way is when the guitar is new, you can remove the screw and harden the threads with thin CA. The toothpicks is even better, IMHO, because you're really compressing the fibers and then hardening them in place with the wood glue, and they get rock hard. __________________
Shut up and play yer guitar
http://itadakimasuanime.files.wordpress.com/2013/06/onigiri-01.jpg
^ I had tae google that Bro.......it does not look like food tae me man,it looks like ( your sig pic ) a toilet seat covering number that one would take tae a public toilet so one would not catch VD
the other pic with rice looks scrumptious....Mmmmmm Oniongirls
