Nil Satis Nisi Optimum
There is arguably less of an issue with a straight all valve amp. But this is all a matter of choice and opinion. With my gear I prefer to err on the side of caution. YMMV.
Also, is this socket tester the same thing? http://www.maplin.co.uk/p/mains-socket-tester-wd53h There's been a lot of talk (at least on wikipedia) about fake electrical stuff being sold on amazon and ebay, and I didn't find any on amazon which were being sold by Amazon (which I assume, maybe naively, would be less likely to be fake).
Yeah our trips blow all the time. The stupid lights in our living room and hall are always blowing it (they're those sprays with several small lights, I think they're prone to overheating and blowing ) ).
Have you checked your average incoming mains voltage? (if you know how to do so safely!) .
"Our" last but one workshop was at an average of 254volts! If you put two 500va Variacs on at the same time a 32A breaker was likely to trip.
The utility companies are only checking the sub taps as and when work needs doing.
Dave.
Our normal lights don't blow any more than you'd expect, I'm guessing they'd be blowing too if there was a problem with the mains voltage?
