That's the plan. Used it once already and panic'd, went straight to my on-line banking and paid it off. And that was for a £30 purchase!
Guessing I'll be OK for now...
It's actually the reason why I don't use a direct debit -- I'm a lazy sod I might be tempted to not bother checking the statement. So I've set up monthly email reminders not to forget paying manually by bank transfer. But it "forces" me to check the statement.
Although it's only happened a couple of times in gawd-knows how many thousands of transactions I have had fraudulent entries on the statement. You just report them and the credit card company sorts them out; it's not actually a problem. But checking the statement is the only way to spot them.
Or do you mean actually get in debt and then pay it off?
Noob questions I know, but having never done this stuff before I'm a little green (sic)
Although the second doesn't hurt your credit rating as long as it's not excessive and you pay at least the minimum.
Your credit rating is a guess at how likely you are to pay future credit off, based on how you've handled it before, so you need to use it to have a rating. Not borrowing ever doesn't really help.
Oddly, my credit rating has actually gone down a notch since getting the card! I assume that's a result of the credit check that happened in order to get it in the first place? Went from 890 to 844 on Experian.
Good luck and well done.
