So I was thinking something like this could be cool:
Take an input, and when a momentary switch is pressed, spit it to the SEND. You have a RETURN also. Return signal is always passed to the main output.
Idea being, you could put it after a stereo reverb or delay pedal, and take the send back around into the 2nd input of the delay pedal, and essentially create a feedback loop. The delay would essentially start to oscillate to all fuckery, but when you release the switch, it would echo off as you'd expect the delay to do so.
Thing is, you could have all sorts of other effects in there, like a chorus before it hits the delays 2nd input for example.
Doing it with a reverb would be interesting. Anyway.... a small utility pedal, I'm sure it'd be pretty easy to make.
There was one that applied pedals to the most recent repeat and that didn't get fed back in.. and another that compounded the function on compound echos ... that's kinda what the Echo does so if you octave the signal it ramps up and up and up till only Dogs and Superman are dancing to your guitar licks ;0)
Phase, Vibe, Flange chorus
MXR MojoSound Elec Miss Ce1 in the order. Pls someone make it me.
