Boost/OD pedal I've got a Digitech Bad Monkey that I love. It's pretty much a TS Clone I believe.
Delay, I'd love a EHX Memory Man (There's a beat to sh*t one on Gumtree for £90 that I really want but have no funds for)
Delay - Boss DD-6/7 or Digitech Digidelay (excellent on a cheap budget)
Wah - EVH Crybaby, or Ibanez Weeping Demon (Be warned they're massive) Standard Crybaby.
CHorus - MXR Microchorus (absolutely my fav) of Digitech Multichorus (great budget chorus)
Boost depends on what you want
Volume MXR Microamp in the amp's loop
O/D MXR Distortion+ tightens the low end, add some sparkle to the top end, and is generally awesomes (and Randy Rhoads used one)
Boss SD-1 nice pretty smooth adds gain/volume and has a mids control.
Boss DS-1 rougher, nastier than the SD-1, mids control
Digitech Bad Monkey grittier than the SD-1, bass and treble controls.
Digitech HotHead like the SD-1 but has bass and treble controls.
others
MXR distortion3
MXR Custom Badass O/D or Distortion (or both........)
MXR Zakk Wylde
In fact, it might be worth you getting a wah and a tubescreamer (a keeley TS9 for example) first, and using your GT8 for all the other things, while you make the transition. The chorus and delay are both very good, and the boost is more of an attenuator rather than an amplifier, so it can all go in the loop without you having to worry about 4CM.
If and when you start replacing the others, I'd go for analogue delay and chorus first (esp if you're using them for effects not 'special effects' like The Edge), then you can keep the entire signal analogue. Keeley do a beautiful Ibanez AD9 and Boss CE2, but the stock ones are also good. There are also modded analgue delays that give you 600ms rather than the standard 300ms.
Viz, I was actually thinking about getting a wah and booster pedal initially whilst still hanging onto the GT8. So glad to see someone else thinks it's a good idea.
Wah - Ibanez Weeping Demon
Chorus - errr... not a clue on this one. EHX Small clone I guess
Boost - anything will do
Compression - Xotic SP or Marshall edaward if you are on a budget
