Im trying to possibly lose the out of phase type sound and have normal wiring but not sure if its still coil tapped bridge in this suggested wiring they have sent me? Is it still out of phase?
I was under the impression the pickups were out of phase with each other and a cap but also coil tap bridge.
The lower diagram is the simplest neck/both/bridge circuit. This could still involve phase reversal if the pickups are of magnetically opposite polarity.
In both diagrams, the same colour coded conductors are connected to the selector switch in the same order. Hence, no electrical phase change has occurred. Instead, phase reversal would involve repositioning the magnet(s) in one of the pickups.
https://www.thefretboard.co.uk/discussion/257153/duesenberg-middle-pick-up-position#latest
Would love to hear clips if you get time later.
