Best pick/thumbpick I've tried
OilCityPickupsOilCityPickups Frets: 11878
edited June 15 in Guitar tFB Trader
These things are in the process of transforming my life!
With the new band I'm doing a lot of lead mixed with Travis picking and it's been a nightmare for me! I have never really felt very comfortable with hybrid picking, it just feels that I want to be using 'P-IMA' like I learned when I was a kid ... thumb and first with a bit of second and third fingers chucked in the mix. Problem is I also have never got on with Brian Setzer's 'tuck the pick back in your hand and then bring it into play for single note lines ... it all starts fine ... then I pick juggle, drop the bloody thing and bugger myself up for the rapidly approaching lead part!
I tried conventional letter q shaped thumb picks, but regularly caught a string under the gripping part ... and found them dick all good for lead.
Enter the Black Mountain pick ... a thumb flatpick in several gauges, where the gripping part is hinged and spring loaded to gently but firmly grip your thumb. Bloody fantastic ... as intuitive to use as any ordinary flat pick for lead lines ... but stays firmly where it's put when you want to Travis pick ... so simple .... so good!
  • FunkfingersFunkfingers Frets: 15225
    I have, at various times, been inspired to try thumb picks by the likes of James Burton and Tommy Emmanuel.
    I always dislike the way that the conventional one-piece design tries to strangle my thumb. Instead, I grow my nail long and use that. This gives me the choice of callus, keratin or both. Plus, no possibility of dropping.
  • guitars4youguitars4you Frets: 15382
    Interesting thought on this - I can of have a 'poor' hybrid picking at times - Totally self taught on this but not a style that works well and/or would suggest others copy - But think I should go down a more 'suggested' route - Saw the Eagles the other day and noticed on the close up screen shots how S Smith uses a thumb pick
    Call me stupid if this is the case - But when I've dabbled at it, I've always had the pick on the nail side - Just assumed it was correct -Yet it always felt like some weird growth on my thumb that never worked - Hence never stuck with it - Yet noticed that S Smith has the pick part of the thumb pick on the flesh side of the thumb - As though it is a pick between the forefinger and thumb
    So now I"m not sure which is correct/best, or indeed if both are par for the course - Yet how S Smith has it appears to me to now be more logical
    Further more others have told me that you want the pick part to be as small as possible, which is how I use a normal pick, with only a tad sticking out - yet S Smith has 3/4/5 mm sticking out
    Yet I'm also a B Setzer fan and note he just goes from normal pick to thumb, as/when required and when in teh thumb mode he kind of 'roles' the pick into his grasp for safe keeping - I know I'd drop it if I tried it
    So the question is, should the pick part of the thumb pick be on the nail side , or the flesh side - Or doesn't it matter
  • OilCityPickupsOilCityPickups Frets: 11878
    They are actually shaped to fit your thumb like this ...
    Weird isn’t
    For nearly 50 years now, when I’ve dabbled at it I tried it the other way round- never dawned on me to try it above yet my way never felt right
    looking at S Smith he morphs between a hybrid style with fingers as well - But if thumb pick alone, he has his fore finger pushed tight up to the thumb pick so it functions like a normal pick
    edited June 15 tFB Trader
    Weird isn’t
    For lead work I just grip the other side with my first finger and treat it like a normal pick ... because that's what it feels like ... albeit a normal pick I can't drop however ham fisted I am.
    I suppose the down side is that they are a bit more expensive than ordinary flat picks ... but then they are harder to loose!
  • OffsetOffset Frets: 13906
    @OilCityPickups ;I will give one a go.  I've always grown my right-hand thumbnail long for this purpose but it cracks and splits all too easily.
    I normally use a 1mm plectrum thickness - would that equate to a 'medium' gauge?
    Offset said:
    @OilCityPickups ;;;;I will give one a go.  I've always grown my right-hand thumbnail long for this purpose but it cracks and splits all too easily.
    To me the grey ones ... medium ... I now use feel just a smidge stiffer than Dunlop 0.71 I used to regularly use.
    My thumbnail and fingernails crack like a bastard ... the doc put it down to huge doses of steroid as a kid for asthma and eczema ... I really need to visit one of the many nail bars locally and get a false index nail fitted ... have done this before and it worked a treat.
    Brill - many thanks.
    Ordered! Will let you know how I get on.  Thanks for the PSA.
    You are most welcome ... :-)
    Picks are such a small thing compared to our guitars worth hundreds and even thousands of pounds ... but if they aren't working right for you its such a handicap.
    PS ... for anyone wanting to get the proper Grady Martin/Paul Burlson - Train Kept Rolling picking from the original Johnny Burnette version ... this pick is a godsend ...
    I use a 2mm Dunlop Stubby so need to look which is suitable for me to try
    https://blackmountainpicks.com/pages/thumb-picks
    Justin Johnson is awesome player - check out some of his work on YouTube - his version of uptown funk is excellent
    Eaglemusicshop.com look a good option to buy in the uk
  • rprrpr Frets: 316
    rpr said:
    Tried those ... and of course they are not spring loaded so they fall off WAY too easily for me.  Cos I is ham fisted innit
  • BillDLBillDL Frets: 8975
    @OilCityPickups Could you please do something for me.  If you could measure the width of your thumb between the actual knuckle and the cuticle it would serve as a rough comparison with my own thumb so I have an idea whether these will work for me.  Also, did you buy the ones with the normal tension or higher tension spring?
    You know it's funny when I look back at all the various things I improvised and fashioned for myself almost 40 years ago by necessity because some things didn't exist at the time, but somebody with the same ideas ran with them and they later became patented commercial products.  I used to use ordinary thumbpicks and would immerse them in really hot water until they begun to straighten out, then quickly fish them out, mould them onto my thumb, and then slide them off at the last moment before they hardened again to bend them inwards a tiny bit more to act as the spring.  I managed to get a really good fit that way where they didn't cut off the circulation, and I then tapered the thickness of the pick part with sandpaper to make them feel a bit more like a flatpick.  The actual pick part was still the same narrow width though, so I shortened it and glued and screwed on a fairly thick flatpick and tapered the thickness down steadily towards the end with sandpaper.  They worked really well and I probably still have a couple kicking around..
    A ready made spring loaded product of the same idea is obviously a much easier prospect than footering around with hot water, glue, small screws and sandpaper, so I might well buy some even though a balk a bit at the price.
    24mm mate or one inch ... I'm impressed I have a thumb capable as being used for ... er ... rule of thumb :-)
    And mine are just the ordinary ones springs wise ...
    I only bought one initially to try ... now I have several. I was very sceptical ... but for me they are now 'must haves'.
  • sev112sev112 Frets: 2983
    I okay with versions of these kinds of things every few months or so, as a mainly finger picker acoustic player who has bitten his nails for >50 years so I play with m6 pads, which is fine, by5 sometimes you want a bit more
    My learning this morning is tha5 more than person these things on a different way round with the pick on the nail side - I must have a try and see how that feels :)
    I tried it after reading the posts .... awful is how it feels!
    I think these are at their most useful for electric Travis pickers who mix fairly aggressive solo lines with picking ... for example stuff like Jim Heath or Brian Setzer.
