Dirty Compressor options.
  • GavRichListGavRichList Frets: 7333
    The Accountant is nice. Adds some brightness - at least it did with my set up.
    In the end I preferred the Barbershop v2 for grit and using the sag control to add some compression, and it has a switch to roll off high end if required.
    I want to try more from Fairfield - shallow water, Randy's revenge and meet maude... the list goes on.
    RR and MM are both utterly glorious. You should add the Unpleasant Surprise to your list too - a really unique and eminently musical fuzz.
  • fretmeisterfretmeister Frets: 24897
    UAFX MAX - the red knob is designed to add dirt/OD
    Wasn’t aware of that. It’s a bit big, but definitely interesting enough to try anyway!
