Used hi fi dealer
maidenfanmaidenfan Frets: 198
Could anyone recommend a good used hi fi dealer ?
My cd player annoyingly skips intermittently on some cds. It could just be dust on the lens, and will certainly have a go at cleaning it.
 I remember seeing a thread a while back with some dealers mentioned.
Thanks very much!
  • Emp_FabEmp_Fab Frets: 25598
    Almost certainly dust on the lens.  Any computer repair place will clean it for next to nothing.
    Offset "(Emp) - a little heavy on the hyperbole."
  • nero1701nero1701 Frets: 1658
  • thermionicthermionic Frets: 10019
    It’s definitely the first thing to try but I wouldn’t say that’s certainly it. I have a decent 3-year old Marantz that is now junk because it started skipping. Cleaning the lens didn’t help, neither did cleaning the rails that the optical pickup travels on (the next likely cause according to my googling). Anyway, I hope the OP gets it fixed quickly and cheaply.
    I didn't.  I said it's almost certainly it.
  • robgilmorobgilmo Frets: 3757
    You can replace the CD drive, it isnt hard.
  • maidenfanmaidenfan Frets: 198
    Thanks for all the helpful advice, cleaned the lens......no real difference. Mine is also a Marantz. Will have a look at the retro tech site. Many thanks again!
    Mine didn’t just skip randomly, as you might expect with dust on the lens - it got to a certain point in the disk then jumped back a few seconds/minutes. This would repeat for as long as I left the machine on. Every disk I tried did the same thing. I did think about trying to get a spare optical pickup assembly, but didn’t seem worth the gamble of a) getting the correct part, b) being able to replace it correctly, and c) that would fix it anyway.
  • HeadphonesHeadphones Frets: 1051
    Eventually CD players immitate old record players it seems...
  • exocetexocet Frets: 2066
    It could be a number of things but if the CD Player is long in the tooth - the laser will loose  output power as it ages. Pretty much everything is dictated by that - error correction, and tracking information.
