Others can chip in with their experience but I would assume it will be good for your needs.
Alternatively Strymon also sell their Walwart style separately - this is the same one they supply with the Timeline, El Cap etc. I've used one of those as a separate PSU as well - again no issues.
I know you don't need another 5 outlets or as much power but at £20, it's a useful thing and very good.
https://www.fxpedal.co.uk/accessories-c31/power-supplies-c44/fxpedal-9v-dc-regulated-power-supply-with-integrated-6-way-daisy-chain-straight-tips-p203
Edit: Bugger..they're out of stock but I'm not sure if he can build you a single
warts works noiselessly with my compressor, but it was only when I plugged it into the voodoo labs that I noticed the sound quality significantly improved. I guess there’s only one way to test if there’s any difference with the 1 spot…
Might be worth testing the offending adapter with a multimeter and check the voltage, then compare to the VL.
The One Spot should be okay, but may be the pedal just doesn’t like switch mode power supplies.
