Since it is all but impossible to define how loud ANY amp is in absentia, the IDs are going to be as loud as some, louder than others and not as loud as others again.
You say "heads" so what speakers are you using? I would say that an ID 100 to a 4 Ohm V30 4x12 is going to be loud enough for any sane person!
Yes, you could put the works into a smaller box but you will invalidate the warranty (which is 3 years IIRC?) and to what purpose? The cabinets weigh FA!
Dave.
Feedback
Yes. Most solid-state amps are direct-coupled and so lose power nearly linearly with higher impedance, ie doubling the impedance halves the power. (Most not quite as bad as that, but close.) Valve amps generally have an output transformer with different impedance taps and so can always be matched to the cabinet impedance and produce the same power into any cab - assuming you do match it correctly.
That might work, but be careful because there aren't many guitar cabs which will handle that sort of power. If you use all three of the cabs you have it should be OK though, if the Marshall cabs are 1912 models they should have 150W speakers, and the Peavey cab will be at least that (I think 240W).
So ultimately, the blackstar will still suffer the same loss of power as my SS amp when used through a 16ohm cab, so I'll likely have the same problem?
My thinking behind the bass amp was that something like a 350w into a 16ohm would end up actually being around 100w, and therefore handled OK by these cabinets. My problem would be in future playing a gig with someone elses 4ohm or 8ohm cab that couldn't handle the power (though I wouldn't be cranked).
We don't play stupidly loud. Drummer hits quite hard. Volume on the valve amp usually about 6. I'm just not loud enough with the SS to be heard properly. Really a valve amp is the most consistent in volume regardless of cabs so maybe I should try and find a smaller 50w head. *sighs*.
Thanks for your help everyone.
Thanks for your help everyone.[/quote]
You can get Laney lc50, vc50 combos cheaply and the lh50 head is fairly small and easily portable.
Sound great, too used they are mega cheap, 150-200 quid or so.
Also, the vc50 has 4 channels and a metric fuckton of gain? Bit heavy.
The lh50 does classic metal and can be boosted for more modern stuff, but as a 150 quid clean pedal platform, it's excellent.
