I have a Quad cortex which is being powered by a 12V Power Adaptor by myVolts. This unit is 12v rated at 4amps and has a polarity inverter attachment as the QC is centre negative but the my volts supply is centre positive. The QC requires 12v at 3 amps.
This power supply works well.
I also have a Morningstar MC6PRO which requires 9-12V DC center negative
Minimum 250mA
Is it possible, without any issues,to run both from the 12v supply by using a daisy chain ?
If so if he daisy chain is connected to the polarity inverter does that mean that the daisy chain connectors are then all centre negative ?
Or would I have to daisy chain from the my volts supply direct and then use 2 x polarity inverters?
TIA.
If the power supply is off a switch mode regulated design then it will hold the voltage steady unto the point it's rated current is exceeded.
Because if you invert something twice you are back where you started
