Hi
I need some advice regarding my Fender Deluxe Reverb Tonemaster setup. I'm happy with the cab sim, but I want to know the best way to get better sound going into my interface for recording and live situations.
Right now, I plug the DI out into my interface and use the Jensen and SM57 settings. I use my pedal board for other effects. For live performances, I go straight into the front of house and decide to have the cab on or off depending on whether it's a quiet stage or not.
I'm looking for products that will give me a higher professional sound using cab sim, and I'd like the option to choose between different speakers:
- 12" WGS ET65
- 12" Eminence GA-SC64
- 12" Celestion V30
Could you recommend the cheapest option to achieve this? Also, what equipment should I consider if I want to grow into a setup that I can use with a tube amp and run stereo effects to the front of house?
The Tonemaster is a great choice because it's very simple and familiar to people using regular amps.
If you want flexibility you may want to go down the Helix / Fractal / etc route.
If you are recording on a PC just use VSTs as it's cheaper and offers unlimited flexibility.
