I bought it directly from the USA Towner shop. I have only used it briefly once on my 335/339, so it is in excellent shape!
Includes:
-Made in the USA Bigsby B6 Aluminium Short hinged
- Towner Tension Bar which (will only fit studs/posts in inches, not metric studs/posts)
- Towner drill-less installation with the back metal raiser and the longer screw, which means you don't need to drill the Bigsby to the body if you don't want to.
- The Callaham String-through steel bar was installed, so there is no more fighting when changing strings on a Bigsby.
- Reverend Soft Touch Spring
- Included screws and original spring in case you do want to drill the Bigsby on.
The rivets at the back of the Bigsby are pressed in so the holes are not noticeable when installing the drill-less kit, this rivets can be cut if you desire to drill the Bigsby.
Save some considerable cash with this fantastic kit, I have used mine with my 335/339 guitars and it works like a charm.
Price £200 posted
Pictures:
