The obvious options are either to use a larger screw or to reduce the diameter of the hole. Gluing in part of a cocktail stick is the traditional solution.
Edit: replace the screw and button whilst glue is wet but allow to dry before using it as a strap button.
Nil Satis Nisi Optimum
Every other straplock relies on even more mechanical stuff not failing…
https://www.gluedtomusic.com/products/730/gotoh-ep-b3-large-oversized-strap-buttons-set-of-2-chrome/
