Paint stripper recommendations
I've got a bass body I want to strip back to the bare wood.
Should I get a heatgun type thing or use chemical stripper?
  • SteveRobinsonSteveRobinson Frets: 7226
    If it's a modern bass with a synthetic finish then the paint stripper you can buy in the shops won't touch it.
    Heat gun is best but take care not to scorch the wood. You'll need to sand afterwards to remove any residue.
  • RickLucasRickLucas Frets: 438
    Paramose
  • fretmeisterfretmeister Frets: 25050
    It's a modern cheap Ibanez. The finish is thick and hard as a rock.
    I don't mind if I scorch it a bit - as sad as it is, I've always liked the fire damaged look!
  • droflufdrofluf Frets: 4017
    If it’s got the same finish as my Telecaster had heatgun is the way to go
    It’s really easy, just go slowly and start under the scratch plate so if you mess up it won’t show
    https://www.thefretboard.co.uk/discussion/233558/stripping-a-baja-2022-version/p1
  • FunkfingersFunkfingers Frets: 14921
    edited July 26
    I am part way through doing precisely this to a Jackson Performer PS2 body.
    I have managed to leave the majority of the sanding sealer coat on the rear and sides of the body.
    The front features a waffur theen flamed veneer that had been dyed. Sanding and/or rubbing with wire wool to remove the dye has worn through the veneer in a few places.
    I need to decide between disguising the goofs under opaque paint or making a feature of them by going for a Rory Gallagher reliced-to-buggery sunburst.
  • TeyeplayerTeyeplayer Frets: 3353
    Glen’s Vodka -rough as a badgers arse. If that doesn’t get the paint off, nothing will.
    Very nice!
    What heat gun did you use?
    Very nice!
    Thanks!
    Nothing special, one I already had from Homebase/B&Q
