i had a focusrite saffire 6 usb and had lots of little problems. The sound quality seemed fine. I then bought a used TC Impact Twin on here and not only did the problems disappear but there was a noticeable uptick in recording quality which i had been told would be unlikely given they were roughly in the same price bracket. Not saying you're wrong...just my experience of those two
The Impact Twins are good units. TC gear is generally pretty good at the lower end of the price spectrum when it comes to audio.
(I'm supposed to be figuring out how to benchmark AMD against Intel for some image processing we do. Would be straightforward, except we don't have the AMD system we're considering and there are limits on how much can be run on the machines we already have other than the processor speed.)
"bummer so far is my key rig 25 isn't windows 7 compatible."
Don't knock it till you've tried it! The 25 had Vista drivers, might work but if all else fails use DIN in DIN out to the interface. You will still be able to power the Korg via USB.
Dave.
