struggling with line 6 M13 reverbs
BarneyBarney Frets: 627
Been practicing tonight and just cant get the reverbs a delay right ..im using a Redplate CDS2 and the M13 in the loop
Whats everybody use ..i either have to much or to little ..the tail of the rev seems to cut of and when i alter the decay time it sounds to much....plus it seems when i put the amp volume up i also get more fx ...anybody have some good settings ...i only want a decent clean and dirty sound (from the amp) with a touch of natural sounding reverb and one with rev and delay
Just to add..i usually use a MK4 boogie and just get a delay from the M13 and rev from the amp and it sounds great ....dont know why im struggling with the other setup
Any help will be greatly appreciated...
  • Drew_TNBDDrew_TNBD Frets: 22446
    Hold down the tap switch and turn the knob assosciated with the decay parameter in order to fine tune it.
  • CirrusCirrus Frets: 8562
    I found the same with the M series. There's something about the tone of the effects that causes them to either get lost or dominate proceedings - it's very hard to find a middle ground. This is a common problem with cheap digital conversion - it makes things sound flat and hard to place. Funnily enough the older Line 6 stomp box modelers didn't suffer this problem.
  • BarneyBarney Frets: 627
    Yeah it works fine as a delay with the boogie because i use the amp delay ..
    i spent all rehearsal last night messing with it..couldnt get it right at all....then the volume of the amp seems to add more fx ....its a tube driven serial loop with the Redplate ..im wondering whether that is making it awkward to set as well..
  • I'm wondering whether it's the Redplate. I've used the M13 in 4CM through four or five different amps and the only one I had to tweak the effects on was a Laney VC30 which has an oddly-designed effects loop.
    Yeah im sort of thinking that cos it works fine on the boogie ..
  • mike257mike257 Frets: 376
    Is the loop post master volume? Would possibly explain the change in effects balance as you crank the amp.
    No i think its before the master...im going to try it again to make sure it isnt me..i turned the preamp vol up as well so maybe that affected it ..
  • hugbothugbot Frets: 1528
    63spring is the best model I reckon. Also play with the predelay a bit to prevent mushiness
    Thanks..yeah iv been searcing the net and that does seem a good one ...the others i was using tailed of in a horrible way...
