Hi Guys
I have to admit that i'm quite niaive about delays.
As the only guitarist in the band I play in i recognise that Delay could really help with the sound that I'm producing.
So far (after years of playing) i've been reluctant to use delay as it often sounds that I'm playing in a bathroom and I've often thought it makes my playing sound worse, however i recognise this is probably an important tool that I should be using.
So any tips/ideas on how to get on with a delay pedal?
Curerntly i've only a really cheap Belcat Delay pedal however am wanting to upgrade to something like a Boss DD3. The delay goes straight into the front of the amp rather than through an FX loop.
Thank you
Watch youtube for tips/tricks / listen to songs that have used it well
Here's the current settings on my DD-6
Level - 50%
Feedback (repeats) - 25%
Delay time - 60%
Mode - 300ms
Like monquixote said, starting with everything at half-way is good for most pedals (it's how I test to see if I like a dirt, chorus, flanger or phaser), but for delays, start lower, and find the best place for each control.
