Dust in pedal footswitch?
The switch has been a bit glitchy in my liquid sunshine recently - sometimes I'll get a slight crackle or volume drop after switching. If I cycle the switch again it usually goes away for a while.
I sprayed a little bit of switch cleaner into the slot through the top of the pedal, which sorted it for a while - I don't fancy taking the pedal apart to get at the switch properly. Any easy way to make sure it's free of dust?
  • TheCountTheCount Frets: 274
    Try  and blow it out with compressed air if you think it's dust. They can just go tits up though, might be easier to swap it for a new one
