Not quite, since the loop still comes after most of the distortion - but it does still seem like a poor design to me, both because of that and because it puts the loop at much too high a level for many FX units that aren't designed to handle line level.
You can also change the pre amp level out on it as well to compensate for the fx loop though @digitalscream ?
Just to slightly piggy-back on this thread- can I do any of my pedals any harm trying them in the Jet City's loop? I'm happy to give them a try and report back which ones work, but not if it fries them! )
(I chanced the Hardwires because they were supposed to be ok in the Jet City's loop, according to this thread: http://www.guitarampboard.com/forum/viewtopic.php?f=5&t=1615 )
My two cents........
I've a 22H going through the standard Harley Benton 2x12 (simply couldn't afford the greenback version).
As long as you don't need clean it's got enough volume for most gig situations. For your regular pub gig I have my crunch channel on about 3 with the lead channel on about 4 (i use this only for solos which is a bit of a waste I know).
I too was torn between the 22 or the 50 head, I can't quite remember the reason why i chose the 22 (probably money again) but i think it's great and also with my 2x12 on it's side it makes a great looking small half stack.
My main advice on either amp would be to retro fit a jack socket to the footswitch and use a spare lead as they're not the most robust out there.
