A: To find out the stored settings in any given Flextone program, hold down the SAVE button while turning a knob. The Manual button will light until you reach the knobs stored setting, at which time the Manual light will turn off and the location of the knob will reflect it's stored setting. Hold down SAVE and TAP to view the secondary settings.
If you dial in a sound you like simply hold down button A, B, C or D for three seconds and it will be saved. There's no way of seeing what the saved knob settings are on the front of the amp.
You can connect the amp to a PC via midi and use the editing software.
