Two Mac Minis for sale, one perfect recording machine, one a good media centre...
Right, the newer one of these is a 2.4GHz dual-core, souped up to the maximum 12GB RAM and fitted with a 256GB SSD hard drive. Hence a pretty brutal compact recording machine; downside of it is that the optical drive doesn't work, but who uses one these days? I borrowed an external unit to install Logic and haven't needed it since; in very good condition, one TINY mark on the top edge. Looking around the £250 mark for this.
The other one's an older 1.83GHz Core Duo, as far as I remember (I'll confirm when I get ten minutes to hook it up!) 1GB RAM and the standard 80GB hard drive - been doing me sterling service as a media centre, and should do the same for someone else! £100 would take it.
Both of the above prices for the base Mac Mini (and power supply / cable as applicable); as you can see from the pictures I've also got a wireless keyboard, wired mouse and remote control which I've been using with both of them. £30 for anyone who wants those to go with their lovely new Mac
![;) ;)](/plugins/EmojiExtender/emoji/fb/3.gif)
ideally collection from Birmingham, but drop me a PM to talk about postage if you're interested...
@DiscoStu - you can either use the Mini's DVi output if your TV has a DVi in, or you can get DVi - HDMI cables which would allow you to. The media centre / internet streamer thing's ideal for these, and exactly what I've been using the older one for as if you keep them clean even older ones can still run fast enough for HD streaming etc. I'm not sure what software's installed, but I doubt I'd have got rid of Garageband or iPhoto if indeed I got rid of anything so it'll hopefully all still be there - I'll check!
Although I HAVE had interest for a package deal for the lot, which is pleasing to me...;)
