Funnily enough, I did hear quite some hiss from the amp and was told it was because of all the lights and stuff in store. Hmmmm!
Anyway, now I want a vibroverb quite a lot. It had a nice deep clean, but got dirty in a nice, gritty way - more like a tweed than the blackface looks it was going for, imo. But plenty of brightness on tap if needed.
Very nice thing. Gasgasgasgas gimme a vibroverb reissue.
I loved the sound so much, I'm thinking of asking Martin at MJW if one of these would be possible, but with negative feedback to reduce the hissiness, master volume and no reverb or trem (effects loop instead). Maybe head and cab rather than combo, too. And 1x12 for a better range of speakers.
Just be aware that the 10" speakers will have less headroom. I've got a 70s vibrolux, and it sounds gorgeous clean, naturally drive, and with some OD and boost. Can't get a coherent sound out of it with a distortion pedal at volume though. May not matter if you're not into the heavies.
My dream amp would be... A broadly fendery voiced amp with 40-50 watts, fairly smallish-medium head form, mids switch (helps MASSIVELY if using as a clean pedal platform for heavy stuff as fender amps are a bit too scooped, should help level things out), good master volume (MUST HAVE THIS!), big power valves (they always seem to suit me better, though I'm a sucker for an ac30) and effects loop.
So in a single channel amp, I could get cleans, dirtier cleans with master volume and a more middy pedal platform amp that likes quite a bit of Marshally and more modern gain.
The effects loop would let me run a solid state heavy preamp direct into it - which is nice, letting me completely bypass the preamp and get essentially a 40 odd watt metal amp.
So a single channel, do-it-all monster.
http://www.guitarworld.com/review-traynor-yba-1-bass-master-tribute-guitar-amplifier
Eqd Speaker Cranker clone
