Does a switchable version of this exist? I'd love to have an expression pedal connected to my Pitch Fork and then, with the flick of a switch be able to use it as a regular volume pedal.
The Boss FV500L has an expression out but it looks as though you either use it as an expression or volume pedal. I don't really want to be faffing with swapping cables - just want to leave everything plugged in and choose with a switch.
Any ideas?
As far as I'm aware you have to use a stereo TRS cable to use a volume pedal as an FX expression. It's not the volume pedal that's the issue, it's the signal to/from from the device you want to expression control that you can't do with just a standard guitar cable. I'm not aware of any combi-pedal that works with a 'flick of the switch'.
The Dunlop DVP3X is a goodie, and has separate tuner and expression inputs in addition to the standard input/output jacks, plus you can reverse the heel/toe positions, adjust treadle tightness, and set min/max levels. A thought I had is that you might be able to connect with both cables at outset so you didn't have to plug cables in/out, but then run an A/B switching pedal that would let the signal switch between the TRS and normal input, letting you kick in either by foot control. Otherwise, if you plugged into both the normal input and TRS input the pedal either wouldn't work or one or other function would kick in by default. Whether the Dunlop will let you do this ie have both cables connected at the same time, I don't know. If it was designed to cut out with both cables inserted at the same time, then an A/B splitter wouldn't help. But definitely worth finding one in store and trying it with an A/B.
http://www.jimdunlop.com/product/dvp3-volume-x
Interestingly I recently discovered that you can use a passive volume pedal as an expression pedal - I have a an old passive Carlsbro volume pedal that I'm going to try this with:
http://www.strymon.net/2011/10/10/strymon-tech-corner-3-volume-pedal-as-an-expression-pedal/
I quite like the idea that you could use it as one or the other or both at the same time. Probably not something you would do a lot but being able to increase volume and an effect parameter at the same time might be neat for occasional use without going down the multi fx or midi route.
The advantage of the Boss is that it's a stereo pedal so the expression and volume functions (if you're using it in mono) are already separate - you just have to find some way of switching off the volume function when you want to use it as an expression pedal. If you didn't want to mod the pedal then a loop-switcher would certainly do it.
If you also want to have the effect pedal with the expression control turned on at any time you're using the volume pedal (even if you're not using the expression function) then it's more complex still, but it could still be done by modding the pedal.
That seems so close and yet so far...
Ah, interesting! But the Alesis F2 has been discontinued - its listed on their website as a legacy product. So unless you can find a store that has old stock, it looks like E-Bay or Gumtree to try & find one used.
My music:- https://soundcloud.com/hubobulous
