Suhr Riot - usage queries
StefBStefB Frets: 2355
Best used with what types of amp?  As an extra channel, lead boost, or what?
I know there's plenty of experience of them on here, so thought I'd check what the general consensus is before taking the plunge.
  • I used mine as an extra channel into a slightly crunchy amp.
    Sounded great into a clean amp as well.
    Changed the character of the amp quite a lot though, so for me didn't work that well as a lead boost, as I like my lead tone to still be similar to my core tone.
  • mike_lmike_l Frets: 5700
    I borrowed one for a couple of weeks, and liked it as an alternative to a dirty amp, I didn't try it as a boost, but I don't think it would have worked so well that way.
  • Straight into a clean amp is how this pedal is designed to work. I use mine into a clean Carr Slant 6 Vand it sounds fantastic.
  • ^^^^^ That's the ticket. Sounds awesome into a clean channel.
    Works very well into edge of breakup too, and adding something like a Koko Boost to it adds a great boost.
    Riots are awesome pedals IMO
  • darcymdarcym Frets: 1297
    the best example I've heart it used was into a badger,
  • John_PJohn_P Frets: 2750
    I use one into a fender twin - sounds fine as a distortion into a clean amp.
  • monquixotemonquixote Frets: 17626
    I've heard it said that it was designed for when you go to a backline provided gig and find instead of giving you a Marshall stack they've given you a Twin.
    It works brilliantly into a clean channel of a Fender type amp. I've also heard it is supposed to work into a dirty amp, but I'd think it has too much gain for that.
    It is a pedal that I luuuuurve.
  • I use mine in to a Badger 30, just on the edge. I also run it at 12V and I feel it opens uo the dynamics and top end a little. Hit the front end with a Koko Boost or a Prince of Tone for leads - sounds phenomenal!
    I had one didn't get on with it. There really well made. The best foot-switch Ive ever tried.
