which pedal for plenty of sustain.....
HootsmonHootsmon Frets: 15993
...but looooow(ish) on compression?
into a clean amp with 'buckers
tae be or not tae be
    ebow ;D
    Pigtronix philosophers tone can, but might be too dirty
    boss cs3, role back the comp?
  • nickb_boynickb_boy Frets: 1689
    If your budget can stretch to it try the Origin Effects Sliderig. Endless sustain at the stomp of a switch!
  • indiansummer1indiansummer1 Frets: 32
    edited November 2014
    definitely wouldn't go for a boss or a dyna comp if you're looking for transparent compression. as stated above, philosopher's tone in theory offers unlimited sustain and you can blend in the dry signal for a more natural sound.
    the barber tone press seems to come up quite cheaply in the classifieds and should also do a similar job (although i've not used one personally so couldn't comment on much sustain it offers).
  • Just watch Pete Thorns demo of the new Keeley comp. could do the job for cleans. If you need sustain with gain, probably a Suhr Riot. Or just lots of volume always works.
  • HootsmonHootsmon Frets: 15993
    ^ yup,sustain with gain...no compression
  • monquixotemonquixote Frets: 17678
    Boss Od1-x
    Super dynamic but loads of sustain
  • joeyowen said:
    ebow ;D
    pretty much my 2 suggestions but I was going to say the Pigtronix Philosophers King. That does clean sustain with minimal compression and optional grit.
    Ed the compressor (Marshall) is always a good cheap option too.
  • xtroublextrouble Frets: 84
    You may laugh, but a Line 6 Dr Distorto pedal has an option for sustain only. You don't need the distortion on, and it has options like a sustainiac pckup. It doesn't work as well as one, obviously, but it does work, and you can probably pick one up for £40 or so.
