This is quire rare and apparently Fryette's favourite amp! Has 2 EL34's and does the fender clean marshall drive as good if not better than my shiva! You can also select Class A and valve rectification for lower voltage and more saggy feel ! Effects loop is one of the best I've tried and you can choose series or parallel! Also has reverb and option to change output tubes to 6L6 with the push of a button ! Last but not least it has the graphic eq which can shape the tone beyond belief , this can be switched on or out of the circuit too!
Looking for 500 for it
Cheers
Cheers
